1
1stC3Vette
Has anyone replaced only the antenna mast on their car. My 89 antenna stopped going up / down. The motor runs and stops as though the antenna would be working properly. I purchased the antenna mast kit, but cannot remove the antenna itself. I followed the directions and removed the retainer nut. I have to pull the antenna up since it won't go by itself. The problem is that I cannot seem to pull the antenna out of the recessed fitting. Is there some trick to this that I don't see? Any help is greatly appreciated.
Thanks,
Dino
Thanks,
Dino
