I had my new stereo installed last Fri., as well as a switch for the antenna,
and everything seems fine but the SYS light will intermittently flash. I very recently had the entire charging system tested and it checked out fine. The digital volt gauge is reading normal. what would cause the light to flash, even after I've been driving for awhile?:confused It doesn't stay on, it just flashes a couple times and then goes out. The stereo job was very professionally done and I don't see where the two could be related but they must be cuz I've never seen that light before. It does it whether the antenna is up or down and like the orig setup, the switch for antenna only is active when the stereo is on.
Thx in advance,
Jeff
Thx in advance,
Jeff
