I bought a Noah cover and am quite pleased with it--Indoor/Outdoor--great fit-- you need to take off the antenna and mark the spot where the ant. goes after you fit the cover where you want it-I used a soldering iron and burned a small hole about the size of a large pea--the burning seals the outside edges of the hole as opposed to cutting and leaving the edges. Reinstall the antenna and ready to go--on the bottom side I put duct tape around the hole just for safe measure--they provide a small plastic ring for that, so I used that on the top. I bought the carry bag for another 5 bucks. The only drawback that I have seen so far is it does take up a little room if you were going to haul it on a trip.
