Anyone buy engines from this guy??
That's the guy that GrandSportC3 bought his engine from, he's raced it hard into the mid 11's and that is driving from Miami to Bradenton for 3 1/2-4 hours first, and then back home. If I ever need another motor he will be the one I buy from.
This is the same guy but not in the auction I e-mailed him....seems like it is not that bad of a deal...
I can build you a 350/400HP for your 81 Corvette. Here is a few of the details about the engine.
*Pro-Top Line Alunimum 200 cc Runners with 2.02" & 1.600" stainless valves with undercut stems to improve flow.
*Screw-in rocker studs with guide plates
*Roller Rockers
*4 Bolt main block In your case I will build it with thedipstick on the pass side to make it match the original better
*Steel crank with 4.84" stroke
*Comp cam .500" valve lift, 270 Duration, 224 Duration @ .050" ground on a 110 Lobe center
*Harden seats for use with leaded or unleaded fuel
*Bronz guides
*Harden push rods
*Double Row timing set
*High Volume oil pump with welded pick-up screen and steel shaht with steel guide
*1 piece oil pan gasket to prevent oil leaks
*Brass freeze plugs
*Edelbrock Dual Plane Intake manifold
*We can paint it what ever color you would like. We paint everthing seperately so it has that show quality look.
*Engine would be assemble with oil pan, timing cover, harmonic balancer, Alunimum heads and Alunimum Intake manifold, along with chrome valve covers.
Because you were looking at the ZZ4 engine I am going to assume your 81 Corvette has a A.T. With our 350/400HP you can re-use your stock flywheel and torque convertor. From the time I receive payment it takes 7 to 10 business days to custom build you a 350/400HP from scratch. It is $3195 and I will ship it to your home or business with FREE SHIPPING in the continental U.S. You can send me a cashiers check or money order or just call me with your credit card. My phone # is 602-395-0800. We are open 8:00 to 5:00 MST Mon to Fri. We will closing early today Dec. 24 [Christmas eve] at noon. We will be open 8:00 to 5:00 Fri. the 26th.
Thanks Darl
