JAKE
This has been kicked around on another Forum for a few weeks now, and so far, I've only found two guys who've degreed-in their LT1 cam. I'm surprised that so few have done so, but that's an issue for another day.
For starters, I've degreed-in many, many camshafts over the years on both Big and Small block Chevys (so I know how to do it) and I have all the necessary equipment. But, I've never tackled a LT1 before, that is, I've never moved a LT1 cam from how it checked dot to dot.
Specifically, I degreed in the cam to verify the ICL hit according to the cam card specs, but, on a LT1, I never adjusted it any further..
Now, I'm planning to advance my son's CompCams shaft another 2 degrees from how I degreed it in when I installed his new cam several weeks ago. The issue that's arisen has to do with the IGNITION timing being altered at the same time - which I know happens when earlier engines with distributors (back of block) are the type being run. I plan to use an offset bushing installed in the camshaft gear
I'd like to hear from guys who have degreed-in their LT1 camshaft on engines running an Opti-Spark, to find out what, if any, steps were taken to address the Opti rotor movement issue.
Anyone ever degree-in and move their LT1 cam?
Thanks,
Jake
West Point ROCKS!
Thanks,
Jake
West Point ROCKS!
