Jon S
81I13 - NOV 80 - Idle Speed Control - Replacement Procedure;
82I144 - MAR 83 - Idle Speed Control Assembly - Repair Kit.
I'm wondering what they mean with Idle speed control. As a 81 corvette doesn't have a idle speed control solenoid (In a rebuild manual I've seen later E4ME's do). Could it be the Idle rpm solenoid for the AC?
Greetings Peter
The way I look at it is this. What can make your engine turn open the airvalves in the carb to WOT (because that is what is happening I think).
Something like your foot, broken return springs on the carb etc etc. But the way it's happening I'm thinking about the cruise control. The cruise control is also controlling your carb and this problem is common on cars with a old cc, but the cc normally only goes to WOT when it is misfunctioning AND when the cc is applied! (so not on it's own). Maybe a idea to remove the link from the cc to your carb and see if it's still happening.
Greetings Peter
