Todds82
I've seen hyperchip makes a performance chip for my 82 crossfire, has anyone used one of those and what's your feedback? I'm looking for ways to tweak a bit more performance out of it. Thanks in advance!
Thanks for the info! Are you running a cooler thermostat in your vette too?
Thanks Lakeside, i ordered the street runner chip. I'm assuming it's a pretty straight forward install?
I haven't taken her out yet but definitely I'll let you know.
Btw, have you done anything as far as removing the smog equipment on yours?
Been meaning to circle back around on this post. I have to say Ive been very pleased with the difference the performance chip made. The vette has been running great without any issues, until yesterday. I went to start her up and and it didn't seem to want to start...i had to give her a little gas ,it started but wouldn't idle, it seemed to idle low anyway, like around 6 or 7. I finally did get it running and went for a drive, ran perfect, very throttle responsive and idled smooth, but again seemed low. This morning had the same issue, turned over fine but didn't start unless i gsve it some gas, then wouldn't idle...any thoughts? Like I said, seemed to run perfect otherwise.
Thanks for the info on the chip, well worth the money!
