T
TooTall
Got a GM reality check this morning.
Weather has been a bit cold this morning so I decided to put the top up for the first time. Noticed that something was just not right on the drivers side. A small curved rod about 12" long hanging down from the top with a busted adjustment screw. (Thread that goes into the ball joint section sheared off) I took the pieces apart and took off for the dealership.
Parts Guy could not identify and I could not recognize from the printout so he sent me out to Tech Guy. Sure enough he spots it as item #16 on the attached file. He said that I would have to buy the whole assembly as the screw in adjusted was not a seperate item.
By this time I'm starting to cover my wallet seeing major $$$ departing. Tech Guy was right have to buy whole assembly and remove top to install at $343.75 parts only.
Now this is an adjustment screw that phyically attaches two sections of this assembly together. Why would they force you to buy the entire assembly.
Anyone out there that can tell me if the dealership is looking to make a buck or just poor planning please let me know.
