Automatic headlight door problem 1991
midgetracer
Vancouver, BC
1991 Black on black Roadster
I have just have encountered a problem on my 91. The headlights normally turn on and off when the car is started and then automatically turn on again when it gets dark. The lights work fine using the on/off switch but no longer function automatically. Coincident with this the radiator fans have both stopped working.
The problem appeared similar to a blown fuse. I have checked all the fuses in the passenger side fuse box and everything seems ok. I'm not sure if there is a fuse on this circuit or where it might be. I can't seem to find a reference to it in any of the manuals I have.
This problem has not been intermittent and I cannot find anyone that has any ideas on what may be causing it.
Anyone have any ideas??
Bob
