HallenTi
Just changed the filter and fluid on my 1999 coupe, with an automatic and 29,500 miles.  The owners manual says 5 quarts capacity.  My ALLData account for it also says 5 quarts.  I followed  the ALLData steps to drain and check the fluid (fill to dripping out the drain plug to begin with after drain, then put the plug back, start the engine, run through PRNDL a few times, then with engine running check and fill till drips out the drain hole).  I did that and have it just coming out the drain hole (temp is about 90-110 degrees at that time).  But, when I check what I have put in, I have 4 quarts plus 7 ounces (less that the expected 5 quarts).  I replaced the filter as well.
After initial fill and start up and run through gears, I stopped it and re-topped it off to be certain it was as high as it could be with the engine off, restarted and went through the gears again (total of I'd say 8-10 times total to be sure), then retopped it with the engine running. I'm concerned that it is below the 5 quart expected capacity, but I had the car level and semi-warmed up at the time, and of course, filling it this way, there is no way to "cram" more in than it will take! Any ideas or thoughts??? Thanks, Tim
		 Factory service manual says to change it every 100K in normal use.
