Paddywhack
Hey all...I understand that the auxiliary cooling fan sensor, located between plugs 1 and 3,was an option and not installed on all '86 vettes. I have one, but with the headers installed now, the plastic connector is right at one of the header tubes and is getting brittler by the ride. Seeing that it was an option and not controlled by the ECM, can I replace the sensor with a plug and lose the connector inside the split tubing sleeve?
