b2k microfueler problem solved
J
jim gramms
MURPHYS LAW
I TESTED THE 2 GREY WIRES BY REMOVING THEM FROM THE AUXILARY INJECTORS ON THE RAMSHORN AND PLACED 2 NOIT LIGHTS ON THE END OF THE WIRES. I PLACED THEM ON THE WINDSCREEN AND WENT FOR A DRIVE. AFTER 3500 REVS THEY BOTH CAME ON AND STAYED ON.
WENT BACK AFTER THE TEST DRIVE BECAUSE THE ENGINE WAS STILL MISSING AT HIGH REVS AND NOW CONNECTED THE TWO WIRES BACK ON THE INJECTORS.
WENT FOR THE SECOND TEST DRIVE AND GUESS WHAT NO MISS AFTER 3500 REVS AND SIDEWAYS IN THIRD GEAR.
THE PROBLEM DISAPPEARED WHEN THE ELECTRONICS TECHNICIAN CAME WITH ME ON THE TEST DRIVE.
MAY BE THE CONTACTS WHERE LOOSE OR BAD EARTH.
BACK FOR ANOTHER DYNO NEXT TUESDAY.
THANKS TO ALL THAT HELPED WITH THE REPLY
JIM GRAMMS
DOWN UNDER
G
grapeknutz
Could it be the injector driver in the ECM is giong bad?
8388
Texas
(2) Callaway's (2) ZR1 (1) supercharged 35th
The ecm has nothing to do with the micro fueler. The supplemental injectors work independent of all the other injectors, and is boost activated.
