christophervan
My aux fan doesn't seem to turn on, I direct wired it to test the motor and it works fine...Does it activate from the same relay and temperature sending unit as the main fan?
88 Coupe
88 Coupe
not the temperature gauge?I noticed the connector for that particular switch is pretty much cooked, so I'll look into replacing that as well.
I will slowely but surely replace much of the connectors under the hood, seems the take a hit from the heat and age,
