hi all
stopped by the shop today to check on Baby. Man, my guy really kicked himself into gear lately and keeps making good progress.
He has most of the gaps corrected already but still some fine-tuning to do on them. The green strip you see around the car following the bonding lines is a glue he uses to strengthen the bonding areas. He now has both the windshield and rear window out (we took the rear glass out while i was there). We have all new clips, screws, and gaskets and moldings for the windshield and rear window.
Remaining left to do this week is sand smooth the areas he applied the green glue along the bonding strips, finish sanding the hood surround channels, sand the door jambs, and finish up minor fiberglass work to make sure everything such as the moldings fit correctly and properly flush to the body and finish up the door gap fiberglass work. After that he puts the sealer down than the primer.
He said by Fri (end of this week) the car will have the primer on it!
here are pics from an hour ago:
pic 1: driverside door showing where some reapirs on the gaps are being made. if you remember my last post on progress you may recall this area was completely fiberglassed over and closed up. He than cut it open again and sanded to create the proper size gap.
pic 2: driver door along the roofline. This isn't the best pic but trying to show how much it has been improved alone this area. still not quite finished but a LOT better.
pic 3: showing the green glue he uses all around the bonding lines to make them stronger
pic 4: showing the windshield molding temporarily back on so he can finish test fitting them and make adjustments so they fit perfect and flush. previously the didn't fit correctly because of previously done poor bodywork on the car and they had gaps where they sat against the body especially the corner pieces.
pic 5: right after we removed the rear window
Barry
Barry
