B17Crew
- Joined
- Oct 8, 2002
- Messages
- 1,610
- Location
- Columbus, Ohio
- Corvette
- 96 LT4 Polo Green/Light Beige Interior
Buster1 said:Did anyone else also read in B17's link about the "shift into reverse for engine shutdown." Can that be right??
Vettefan87 said:It is the same way with my brothers 1973 Trans Am he let me drive it once and i left it in first and I could not figure out how to get the key out, I though I broke something, but then he told me to put it into reverse and it came out. I have no clue, why you have to do that??
That is the only thing i hate about my C4Vettelt193 said:reminds me of the 4+3 equipped C4 vettes. you couldn't get the key out of the ignition if it wasn't in reverse
Actually, (and I can't believe that the old guys around haven't remembered this already) the shift into reverse with the manual transmission sounds like a throwback to the late 60s and early 70s, and even into the 80s with the C4. The manual equipped cars had to be placed into reverse because that did two things. The reverse gear linkage had an additional roll of linking the reverse gear linkage rod with the lower end of the steering column that had an inner and outer sleeve in addition to the actual steering column. It turned the inner sleeve of the steering column in which was positioned a "leg" that was the moving pole of the backup light switch. By rotating the sleeve counterclockwise, the switch leg was slid into the ON position by the rotating action.Thereby completing the circuit that turned on the backup lights.MagikDraggin said:Probably because in reverse, the drive train is at its highest rolling resistence setting and isn't likely to go anywhere if you don't set the parking brake, unless you're on a steep incline.
