Battery connection
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
Battery connection. Have never seen a connection of this type. Would like some help on removing. I think I know how it attaches, but not sure & don't want to mess something up. Thank you.
Below is a picture of my 95 ZO7. Had her over 220 years, but time to up grade.
Miss her.
220 years is a long time.
I have never seen one like that, but I would first remove the negative cable, and then loosen the nut in the photo and twist the cable off.
My 2010 Sierra has the same cables. It's just the way they are now. As already suggested, remove negative lead first. It is just too easy to slip with the wrench and end up welding the wrench to any nearby metal when working on positive post. A good habit to form.
Miss her.
Thanks for the reply. Will make sure no sparks fly.
Thank you for the reply.
In addition.
While your'e are at it you might want to attach a quick disconnect Battery Tender terminal. Makes it really easy to plug in and stay charged.
I use a float charger to keep the bat. topped.
Thanks for the suggestion tho.
Merry Christmas.
