George H. Williams III
Gone but not forgotten
All who have replaced the battery know the problem. Does anyone know of a tool/thin wrench to adjust the lower nut (not the mechanic) on the side pannel that has to be removed ? Thanks, George
I use a 10 mm Craftsman combination wrench. Also, I don't remove the bolt. I just loosen it enough to release the lower end of the side panel. Then I remove the panel leaving the fastener in place.
that's where mine is. Change one headache for another, though. I installed a remote + for jumping and charging under the hood, plus a battery tender in the compartment behind the pax.so with the headache area the battery is in lol...... has anyone else considered moving the battery to the hatch area??
GET SOME FUMES???? what kind of fumes?? caused by what??that's where mine is. Change one headache for another, though. I installed a remote + for jumping and charging under the hood, plus a battery tender in the compartment behind the pax.
Rewiring it was a PITA, by the way and I get some fumes. Initially I used a red top Optima, and after two crappy ones, mutlitudes of headaches trying to work with them, I went to a traditional Interstate.
The best battery I ever used was a Delco DuraPower.
So you know what I mean .I'm amazed there still in business .Like yourself all I was buying was ratchets because we are steel contractors .Then the new approach for ratchets is just to give the customer a repair kit with just the parts ---you fix it .adGOOD job Vetteboy..getting them for me! Many years ago they ruined my carpet and never paid for it other than me refusing to pay the bill on my card!
Jump started the car and brought it to Sears for a pro-rated replacement under warranty. They knew it was a PIA and said they didnt do Vettes...then put the battery I'd bought in the hatch area on a piece of cardboard. And I rather stupidly didnt think anything about it.....DUH.....battery acid will leak through cardboard and there was some under the battery from their shop.
Every now and then when my Craftsman ratchets start to look crummy I tell them its broken and make them replace it for free! One day I'll get even for the price of that carpet!
Yes. I don't want to hijack the thread but batteries emit fumes, partially hydrogen gas when they are charged. C3s ad venting tubes that channeled these fumes outside the cabin. I thought the Optima 'red top' was my answer, being fully sealed, but their lousy quality, causing my car to become unreliable, removed that option.GET SOME FUMES???? what kind of fumes?? caused by what??
How do you get at the head of the lower bolt? It seems completley sealed in to me. All I can see are the threads sticking up through the nut. If you open the door wide enough do you get access to it? (I'm stuck in the garage with a dead battery and therefore can't open the door very wide.) Or do I have to take the rocker panel off? ;help
I'm confused ! :confused :W
You can get to the bolt head with an open end wrench and it just needs loostened NOT removed. The panel has a U not a hole for that bolt so it can slide out. Another bolt is located by the door and is accessed from above and you may need to push the car out so the door can open wider. Other fasteners are at the edge of the wheel well, hold down is located on the back side of the battery. While long extensions are not required they do make the job much easier.
