grumpyvette
take the time and effort to read thru the links if your interested in knowning a bit more about bearings
http://www.thirskauto.net/BearingPics.html
http://www.babcox.com/editorial/ar/ar20128.htm
http://www.babcox.com/editorial/cm/cm99828.htm
http://www.thirskauto.net/Engine_Thrust_Bearings.html
http://www.aptfast.com/Flyer_HowTo_Dir/HowTo_Folder/Cam_Bearing_Install/Install_Cambearings.htm
http://www.babcox.com/editorial/us/us90126.htm
http://www.circletrack.com/tipstricks/4636_crankshaft_rod_bearing_installation_tips/index.html
http://www.stockcarracing.com/techarticles/scrp_0509_coated_bearings/index.html
http://www.engineparts.com/motorhead/techstuff/brgclear.html
http://www.engineparts.com/motorhead/techstuff/bearingfailures.htm
http://www.engineparts.com/motorhead/techstuff/clrcode.html
http://www.babcox.com/editorial/ar/ar10180.htm
http://www.popularhotrodding.com/tech/0711phr_bearing_clearance_control/index.html
http://www.tpub.com/content/engine/14076/css/14076_73.htm
http://mahleclevite.com/techbulletins/CL77-1-205R.pdf \
http://www.chevyhiperformance.com/t...rain/0707ch_main_bearing_clearance/index.html
