Want a wheel bearing noise to be pinpointed? Drive the car in a straight line and then steer the car to one side and/or the other side... kind of like a body roll. If the noise goes away, it's probably a wheel bearing. What happens is, you load the bearing to one side and theoretically, it quiets down. It would be a good idea to change the wheel bearings as a set. Meaning, change both left and right wheel bearings. The other bearing is probably heading south as well.
Have the windows down for this test. Find a paved, smooth street with a long, high solid wall next to it. Drive close to the wall and listen for noises on the side of the car that is closest to the wall. Drive the opposite way and notice if the noise is louder? If the sound is louder going in one of the directions, (closest to the wall), it's a good chance that you've pinpointed the area... i.e. , dirver's side/passenger side. Find a buddy for a second set of ears to help diagnose.
