A
ARODFX
I am thinking of buying a Cam for my 87 C4 and wanted to get some info.
Here is my current setup:
K&N air filter (w/Cut Out Lid)
58 mm BBK throttle body
Ported intake plenum and SLP large tube runners
Heads machined and lightly ported. (3 angle valve job and some in/ex work)
True Roller timing chain
Flow master Exhaust and Cat
Relocated Air temp sensor
160 Thermostat
Hypertech Thermomaster Chip
New O2 sensor
The following is what i plan on getting:
Jacobs Pro Street Ignition or Accel 300+ Ignition with Accel 50,000k coil(any suggestions?)
ZZ4 Roller Cam or Higher spec cam if my setup allows (Suggestions?)
Shorty Headers (Y Pipe is new)
1.6 Roller Rockers
Thinking about getting New Heads w/2.02 In-valves 1.60 Ex-valves 64CC chamber.
I want to increase the stock horse power in steps and would like to know what items I listed would show the most gains. Trying to find the best combinations before building the 383 stroker that I want. Any suggestions are greatly appreciated. Thanks!
160 Thermostat
New O2 sensor
1.6 Roller Rockers
