HallenTi
I plan to change the ATF and filter on my 1999 (has just over 28,000 miles now). I have read several different write-ups on changing the fluid, and have looked under it myself. The articles say "Refill the trans fluid" and that is it. No explanation is made of the best way to do that operation.
I just can't see how, from underneith, through the open drain plug, right next to the exhaust, how you can just "Refill the trans fluid". You can't just tip the bottle up and pour like those that have a top-mounted dipstick tube. Looks to me like a suction gun would be the best way to go, but I am looking for some advice.
I know that you put in a specified amount through the drain plug, put the plug back in loosely, start the engine and run it through reverse, drive, reverse a few times, then take the drain plug back out with the engine still running then fill until it is just at the bottom of the drain plug hole. It just seems that the "Refill trans fluid" is a little over simplified. Let me know what you think. Tim
