C
C3RVETTE
Better Performance for less than four bucks?
PLEASE READ OUR DISCLAIMER
3/16/2005
By: Chris Neprasch
3/16/2005
By: Chris Neprasch
Underinflated tyres reduce braking efficiency, handling accuracy and stability.
Ducati M400 Manual Think about this: Tires lose about 1 psi per month. They also lose 1 psi for every 10-degree Fahrenheit drop in temperature. If you air your tires up in June during a 90 degree heat wave and don't check them until a chilly 40 degree November night, it's a combined loss of 11 psi. Not only does it affect gas mileage, this little excerpt was taken from the Ducati M400 Owner's Manual on other effects and those things only have half the wheels. "Underinflated tyres (Yes tyres because that's how them Italians spell it – OVB) reduce braking efficiency, handling accuracy and stability," the manual says.
Now we return to our little present from VandeWater and Bridgestone. A tire gauge is your friend and can be purchased for less than $4 from your local auto parts store. We know this because we left the gift at home and had to buy another one for photography purposes and even we could spare the extra money. And as for the answer the title of this article poses, yes if your tires are severely underinflated you will get better performance and mileage out of your car for less than four bucks. If they aren't, well at least you'll be able to maximize what you already have. A good tire gauge is more accurate than the naked eye and here's the proof: If you had a hard time figuring out which tire had what pressure in the previous paragraph, the same pictures are above this one too and in the same places. In the center shot the tire is at 35 psi, the one on the right is 25 psi and the one on the left is 30 psi.
Tire TechPower Maintenance – Tire Rotation
Wheel and Tire Upgrades 101
The Importance of Winter Tires
Believe it or not, there is a proper pressure for your tires if you have aftermarket wheels with oversized tires or a different wheel diameter. Running the manufacturer recommended pressure for the 205/60/16s isn't always the same pressure required when you switch to a 215/45/17.
The easiest way to determine what pressure you should be running is to contact the tire manufacturer and ask. Tire companies want you to be safe and happy with your new tires and they are usually more than willing to help. Before you pick up the phone, make sure to jot down a few details so they can better assist you. Record the OE tire size for both front and rear. Write down the load index, speed rating and make sure to not miss any prefixes or suffixes like P, LT, or XL. Check the owner's manual or the sticker in the door jamb for this information just in case a previous owner or you have changes the tires before. Also include the OE recommended inflation pressure and if you're putting bigger tires on the factory wheel then don't forget to find out the width of the OE wheel. If you're running aftermarket wheels then include that in the list you're preparing as well as the new tire size and model.
Sources:
Bridgestone
www.bridgestonetire.com
(800)-362-3872
