scottygrant
New member
Hello all. I've got a 1971 454 that I put a Torker II manifold on as it's the only one that *barely* fits under the hood. A few questions for those who may have some experience with the under-hood limitations of the LS-5:
1. The Torker II is OK, but I'd rather have more low-end torque. Is there an aftermarket low-rise dual plane aluminum manifold that will fit under the hood?
2. The oval ports on the Torker II are significantly smaller than the oval ports on my LS-5 heads...this seems to be an abnormal situation...is it?
3. I recall there was an aluminum intake manifold for Big Blocks with a "Winters" foundry marking on it. Am I recalling this correctly, is it a dual plane low-rise unit, and can I get one?
I'm new to the group, and thanks in advance for any help you can provide.
Scott
1971 LS5 Convertible 4-speed
Scott
