matthud
As I was on my way home today in the 69, I made a turn then gave the car some gas, went to make the 3 to 4 shift, when I took my foot off the gas to make the shift, the engine didnt drop. As I continued down the road at 50 mph without my foot on the gas I quickly discovered that I could not slow the engine down. I tried to lift up on gas pedal with my toe, but the linkage was where it was supposed to be. I finally got a chance to pull off, and as soon as I pressed the clutch the engine revved to 2500. I could not get it to slow down. I shut the car down and the engine dieseled, which it never usually does. I first checked the throttle linkage at the carb to see if it was returning to the idle screw, it was. I had to slip the clutch in 3rd gear all the way home to keep the car under control. But it really bothered me to have it constantly running at 2500 when I pulled to a stop sign.
What could have gone wrong? I checked to see if the distributor rotated on me but it was tight. So I think this is a carb issue. What should I look for?
