fastglass95
Do you need to do anything differnt from normal when bleeding the brake system after replacing all four calipers and related brake lines? probably lots of air in the system to get out!
I usaully use a "mity-vac" and vacum bleed from each caliper, farthest first, then work towards master cylinder. Then follow with the old "foot on the pedal with a helper" technique in the same sequence just to make sure all the air is out.
What is the "Gravity bleed" technique I've heard mentioned here on the CAC before? would that be effective when replacing brake components within the system?
Thanks,
Thanks,
