MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
Okay, I'm going to replace all four brake hoses, and my master cylinder. I'm going to flush clean DOT4 through the system at the same time. I have a few questions:
First, I'm trying to decide the best way to flush and bleed the lines. I have a vacuum bleeder, those bleed screws with the check valve, and I can build a simple pressure bleeder, if y'all think I should. I need to get the old fluid out, the new fluid in, and then remove the air. Should I drain the system, then fill with new fluid? Or should I use the new fluid to push the old fluid out? In any case, do you recommend the vacuum or the pressure? (the check-valve screws are just there for added insurance - I'm never going to pedal-bleed these brakes again
Second, I understand the basic theory behind bench bleeding the master cylinder, but I'm somewhat stumped on a couple points: how do I get the master from the bench to the car, without losing fluid (or will it not drip enough to matter)? And, if I'm pressure bleeding anyway, do I really need to bench bleed the master, or will the pressure bleed take care of it?
Joe
Joe
