It doesn't look like you're down to bare 'glass yet to me - I think it looks like bad previous bodywork. Get the area down to bare 'glass and then evaluate what you have going on.
And what grit paper are you using? Your sanding looks too fine for doing the rough-out blocking. Switch over to 80-grit and a long file board and knock the heck out of that thing. The photo looks like you're sanding with about 150 or finer... that won't work real well.
Lars
The tape is coming thru when I block sand. Also some thin cracks on the tape edge. Do I deepen the crack and put fiberglass filler? Thanks Ralph
