It's been several weeks since the ole Blue Bullet's HVAC quit in Vegas. I had the compressor off, but then the car sat in the shop for a week or so while I waited for parts and took care of some other work-related assignments. I got back on the compressor installation late last week and finished the job today, but there was one oh s**t moment.
Once the coolant pump was back on, new Continental Elite drive belts (PN 4040417, 4060798) were installed, the coolant hoses were back on, my Zip Products Mamba air filter assembly was reinstalled and the cooling system was filled, I went to start the engine and cranking time was excessive. Once it ran, the service engine light was on.
Oh crap! I thought. What in the hell is wrong now. I connected the Actron CP9680 scan tester we have here in the shop and read a P0340, a fault code for the camshaft position sensor. Well, heck, that explains the hard starting, I mused. I figured the cam sensor was at the front of the engine somewhere. I fired-up my Panasonic ToughBook and went to ACDelco's GMSi web site and brought up the factory service data for a '12 Z06. GMSi showed the camshaft position sensor on the driver-side front of the engine. I pulled my trusty miniMaglite out of the tool box and looked between the alternator and the power steering pump and there it was amongst the accessory drive pulleys and the wiring harness plug had come partially out of the camshaft sensor just enough to break the connection. WTF? :confused I thought. How in the heck can a locking connector just come loose?
After thinking about this for a while, I decided that during the coolant pump removal or reinstallation, I must have snagged the release tab of the plug then pulled it partially out of the sensor. As I continued to look at the partially dislodged plug, I starting to get
ad pissed off thinking about how much work it was going to be to gain access to that plug and push it back in place.
More head scratching...
Then I hit on the idea of using some long, flat bladed tool which I could push down between the pulleys, then pry the plug back into the connector. First I tried my king-sized, extra long pry bar. Too big. Then I tried the long, small-diameter screwdriver I use to adjust Holley idle mixture screws. I was able to touch the plug with the end of that, but the tool was too flexible–I could not apply enough force to push the plug in place without bending the tool. Finally I tried my largest flat-blade screwdriver, which is smaller then my killer pry bar, but more rigid than my Holley mixture screw adjuster.
That worked like perfectly. I positioned the end of the screwdrived at the back of the plug then pried upwards and...viola! The plug snapped back in place.
As I'd just saved myself a lot of work, I broke into my happy dance.
On Tuesday, I'm going to take the car into Bunnin Chevrolet for them to evacuate and recharge the system with refrigerant.
Hopefully, that's going to solve my HVAC problems.
