John Mcgraw
- Joined
- Feb 18, 2003
- Messages
- 816
- Location
- Austin Tx
- Corvette
- 1960 Roman red, 1959 resto-rod, 1965 resto-rod
Hi guys,
I have been really busy at work, and have not been able to work on the car for the last couple of weeks. This weekeend, I dropped the body back on the frame. I have been running wire and am just about through with this task. I am running all the wire behind the inner fenders so that when you look under the hood, you will not see any of the wiring. The engine control wiring will also be pretty much hidden from view by the fuel rail covers, so it should make for a pretty clean looking engine bay. Saturday, I fabricated a couple of heat shields to go over the pipes and mufflers out of stainless. I was worried about the asthetics of them, bit I needn't have been concerned, since you almost can not even see them from under the car. If you look in the pics, you will see them hiding above the mufflers, but you really have to look for them!
They have almost 3/4" of air space between the top of the shield and the floor pan, so they should be real effective at keeping the heat out of the cockpit, especially when coupled with the floor pan insulation that will be going in. I got my upholstery material chosen and ordered, now all I need to do is get my upholstery guy motivated to get started. I can not get my dash in and my wiring finished until he at least gets the leather on the dash pad.
I say leather, but in fact, I have followed the lead of most of the street rod guys, and am using ultraleather on the car. It is an incredibly soft and realistic leather substitute that is supposed to out perform leather is every regard, with none of the problems associated with it. It is a lot more than leather, but the waste from cutting is almost nil, so it should about balance out. It is really an incredible product, and feels like the softest glove leather you have ever felt. At $75 a yard it is expensive but I hope that it will prove to be worth it. It is going to a be a very light buff color. This week I hope to get my splash pans fabricated and the remainder of the brake and fuel plumbing completed. With any luck I will be able to get this puppy fired up within a month if I can get my upholstery guy busy!
Check out the folder marked 10-10-04.
http://www.villagephotos.com/pubgallery.asp?id_=339303
