D
dgotrik
I had a 73 fire damaged Stingray totally rebuilt from frame up. Engine, tranny, rear-end totally redone. Original rear spings were reinstalled. New shocks etc etc. I took the body from a 2nd 73 Vette and now when I set it onto this new frame it sits up about 1.5-2.0 inches around the entire frame. The body rests on the front mountings and under the cage on the 2 mountings but it's too high. The rear frame sits about 1/2 in above the bushing. The entire body is off the same 1.5-2.0 height all around the frame. The new front mountings were not welded too high. We needed to weld an insert under the cage because of the rust but that was maybe 3/16 of an inch. The insert was from Paragon so it was a Corvette replacement part. It looks like the bushings are too thick but that doesn't make sense. Any ideas?
