firstgear
- Joined
- Oct 11, 2003
- Messages
- 1,895
- Location
- Norwalk, Ohio
- Corvette
- 15 Z06, 01 Vert, 63 SWC & 60 ALL RED
The tire store that I got my tires swapped out on the car for me told me many many times to double check the torque of the bolts with the new wheels after 50 miles or so and that they should be checked again after a couple of hundred miles....well, I did check and almost all of them were good, only one or two needing some additional snug to get them to 65 ft-lbs...EXCEPT one....that just turned and turned and turned....finally took it off and the threads on the bolt that were engaging the stud on the bolt were virtually gone!!! There was nothing for them to hang on....so if you got the new wheels and bolts provided by the supplier, I would suggest double checking them as well.....off to the parts store to see if they have the longer type of wheel nuts....
good luck!!!
good luck!!!
