Zero1Niner
Just installed my Borgeson steering kit this weekend. Really nice improvement. I will post about my install experience later, but wanted to ask about some concerns I see right now.
1) I'm seeing a lot of flex in my chassis when tuning through the full range of left to right. In fact, i see it when any steering input is made. It's a little concerning. Anyone else have this problem? Any long term consequences? Maybe it did this with the factory system too, but I'm not sure i noticed it the pronounced. I realize the torque of the Borgeson is much more dependent on the frame structure than the factory system was, and honestly I can't remember how much flex was happening before the install, but I felt a bit uncomfortable with how much flex I am now seeing. I know I already have a slight frame crack forming on the same side under the a arm, so I'm sure this is going to accelerate the need to get the frame welded. I will need to remove the entire driver side a arm to weld it properly...I think.
2) when I turn to the stops, I get a squealing noise and it bogs down the engine a bit. Normal? Air in the system? Bad unit?
3) there are certain points when I feel the turn of the wheel is not perfectly smooth throughout the rotation. Like a funky dead or weak spot now and then..but not consistent. It's small, but thought I'd ask if others have this same thing.
Would love your feedback and comments. Thanks!
Oh yeah. It's on a 1981 mostly original.
