D
Dcalebaugh
Well I figured out how to install the speakers(see my other post) but when I turned on the system zip. I could hear the power ant relay but not the amp relay.After much searching, I found the relay, got to it by removing passenger side lower trim. I jumped out the relay and bingo all 4 speakers worked. My question, is there any other connectors in between the radio and the relay? I first jumped between the feed and the switch leg, then I feed 12volts to the coil of the relay and it also worked. The relay is not getting the 12volt feed to the coil from the radio. Any suggestions?
Dave:duh
Dave:duh
