Bose Radio (CDM unit) connector pinouts
  • Thread starter Thread starter scarbro2k
S
scarbro2k
Whilst cleaning out the accumulated crud in the boot behind the
passenger seat on my 94 coupe, I pulled a little too hard on
the radio wire harness and a wire came out of the connector.
The BOSE CDM unit has several connectors. The wire that came loose goes into the two connector set that has a total of 15 pins.
8 pins on one connector and 7 pins on the other. I believe it goes
in the 7 pin connector. Not all of the pin locations on the connectors are occupied. I have looked at the various websites
that offer wiring harness pinouts. No info on this connector set.
Most of the pinouts are for the Amps and for a different type of
radio unit. I have the BOSE CDM which feeds a AM/FM/Cass/CD
unit. The wire I pulled loose is a dark green wire.
7-pin Connector (gray)
Space - Color
1 - BLK (Radio Ground Out)
4 - PPL (Ignition Out)
6 - DK GRN (Serial Data)
9-Pin Connector (black)
Space - Color
8 - BRN/WHT (Left Audio In)
9 - DK GRN/WHT (Right Audio In)
10 - BLK/WHT (Audio Common)
11 - RED/WHT (Battery Power Out)
14 - SHIELD GROUND
15 - PINK (+14 volts out)
Woof! Woof ! You da Man !
Just what I was looking for!
OBTW, where did you get this info?
Anyway Thanks. Now I can can hear all my "Weird Al Yankovich"
cd's again. If I can get the pin to stay in the connector..
Love these forums !!!
You know, I am already using ALLDATADIY for my
wife's 94 XJS Jaguar. :duh
I'll add the Vette to it now.
Between the Vette and the Jag, I'm always busy fixin
something !!
Still a Happy 94 Vette owner !!
:v
