Nobody Cares
- Joined
- Oct 7, 2006
- Messages
- 421
- Location
- Higgins Lake , Michigan
- Corvette
- red 81, orange 74 vert. , 80 claret,69 chevy pu
Bought a 1980 vette the other day, needs work. The Battery light stays on all the time. If i pull the 2 wire plug from the alternater the light goes out. There is power   (with test light ) on bothe side of the 2 prong plug at the alternater. Should there be power on both sides ??? The Gauge is reading Approx. 12.8 amps.   Question 2: If i plug in the white wire to the Distributor for the TACH filter the engine stalls , the white wire is beside the pink wire that is for the Tach. Can't figure out why when i plug the tach filter wire  in the engine will not run or start. ??  I'm stumped .
