V
Vette66AirCoupe
I have just replaced all 4 wheel cylinders, 3 rubber hoses and 2 steel lines, both on the passenger side, one front, one rear. I adjusted up the new brakes and began bleeding in this order. RR, LR, RF, LF. I have been careful to make sure the master cylinder does not run out of fluid as I make my rounds. The problem is that I've been around the horn three times now and have yet to get all of the air out. I've gone through an entire bottle of brake fluid. The master cylinder was fine before I started and is reasonably new so I don't think it's the problem. I noticed bubbles rising in the master cylinder, a small one every 2 seconds or so. This has gone on for over an hour now though the fluid level doesn't appear to have gone down. I'm going to wait until these bubbles stop before I try to bleed again. No leaks anywhere else. Any suggestions???? :confused
