brake bleeding question
Ej46
Cumberland, Rhode island
1976 White coupe
What’s the right way to bleed a brake system? Should I bleed the master cylinder first than go to the back brakes than the front or should I do the master cylinder last after doing the back and front brakes.
Thanks for any help.
With a C3, jack the car up, support the rear on jack stands and remove the rear wheels.
Bleed the master cylinder first.
Then do RR-LR-RF-LF
The rear calipers have two bleeders per calipers the fronts have one bleeder per caliper.
During the time you have the bleed fitting open, tap the caliper casting a couple of times with a plastic hammer.
During the time you have the bleed fitting open, tap the caliper casting a couple of times with a plastic hammer.[/QUOTE]
Didnt think about that trick!
