Brake Booster
  • Thread starter Thread starter James Price
J
James Price
Do I need a new Booster on my 78?
My calipers are rebuilt, Pads are new, Fluid is full, No leaks, Pedal feels good, but I have to push like hell to get the car to stop...
Also, will boosters from others Chevys fit that myay be less expensive??
If it is hard to push, it sounds like the brake booster. Before you replace it, trace the vaccuum line that supplies it. There should be a vaccuum line from the brake booster to the manifold. (or to the lines that eventually lead to the manifold.)
I have no idea if other brake boosters will fit.
Hello JamesPrice: -Is your engine idling excessively-fast, -perhaps you just forgot to replace the vacuum-line from engine to the booster/reservoir-tank! Also, have you tried the simple test of a Vacuume/Power-booster? --you know, start the engine and let it run for say about 30-sec. to fully stabilize the vacuume-circuit, then with your foot OFF of the brake-pedal, -shut-off the engine and let it sit for a minute. OK, now with the engine-off firmly-stab the brake-pedal, ---does it go down like you are getting assist from your booster? --If not, then the big-tank to which your Master-cyl. mounts is either not getting proper engine-suction, -or it is leaking-down the vacuume someplace (possibly at the check-valve or rubber-gromet feeding into the vac.-tank from the engine; -or the internal rubber-diaphragm is shot). If you've already done the above, then maybe something is screwed-up with the hyd.-circuit relative to the trickie proportioning-valve? -or a commonly defective rebuilt/Master-cyl?.... Hope this shade-tree mechanic info. helps; oh, and you might check with a local Power-brake Rebuilder-shoppe owner, and ask them if they know of a cheaper albeit equivalent Power-booster unit that would meet the C3's spatial requirements... -Bob vH
:crazy
While we're on this topic I have mine out as I'm doing other work and it needs repairs. I'm also going to be putting in the big block soon. I have heard of smaller diameter boosters but haven't foun one yet. Any suggestions or reccomendations? BTW it's a '71...
The hydrobooster (hydraulic assited instead of vacuum) is smaller in diameter, MUCH smaller. It's a tad longer than the vac booster but not a problem. It runs off the PS pump.
Marck
Is that so? Well, I guess then, I have 2 units here but was too lazy to measure :) I just briefly looked at the HB and the stock unit and thought the HB was a tad longer
Marck
Yeah I know about that but it's a bit pricey in my opinion.
It's not finished by a long shot, it'll take quite some time to finish it. Currently waiting for some more parts, it's a step by step process. Thanks for the compliment :)
