Slvrcld00
I know you've seen this a bunch of times, but Im new here I need info/help. left front caliper won't retract. all new parts.. I can see it retract if I hold it with a c clamp. I can hear and feel a popping in the hard line on the passenger side. If I put it together the left front caliper holds tight. ii took it off and with a c clamp I could watch it slowly apply like on the second or third pump . sooo now I am thinking there is a blockage in the line or a valve sticking inline somewhere. I found the ebcm control( I think its called) in the well behind the seat. but it doesn't look serviceable and only used, expensive parts are available.PLus I dont have the. tools to bleed through an abs unit and it was kind of a pain to do it manually on my truck not sure if it is the same process fo this unit. Now I know its not in the repair manual but sometimes hitting it with a hammer helps ?¿? there is no corrosion visible externally and I have no lights on. Is there a proportioning valve somewhere the can be changed out or is it all in the module?
FYI 1987 Corvette base model
