Craig-o
I took my car out on a great road-course about 2 weeks ago. Having done this only 1 time before, I was aware of the significant stress such an activity can have on the braking system. With 60,000 miles on my '01 I decided to change brake pads (with AC Delco Dura-stop), and as long as I was at it, I flushed the brake system and replaced the fluid with a high-temp brake fluid.
What I experienced was, to me, a bit odd. After the second 30-minute session of the day, and for most all of the sessions thereafter, I experienced a strange phenomenon. The first time I applied the brakes going into a sharp turn, the brake pedal seemed a bit spongy, and didn't grip when I expected it to. However, all that seemed to go away after the first time I used the brakes on that session. In other words, it seemed that my brakes faded the first time I used them, then seemed to tighten up.
I throroughly flushed the system and used a blue fluid for the replacement, so I could tell when all the old was flushed out of the lines. I also bled each caliper and was satisfied that there weren't any air bubbles in the line. I used a pressure bleeder, and had extra fluid left in the bleeder reservoir, so I'm sure the master cylinger never ran dry.
Aside from the Dura Stop pads and blue fluid (from a German manufacturer who's name escapes me), the braking system is stock; no braided flex hoses, stock calipers and rotors -cut once as a result of the tire-store over-torquing the lug nuts, but still well within thickness spec.
Any ideas on what caused this, or what I can do to remedy it? I have to add that I have not experienced this same phenomenon since having the car on the track. So whatever it is (was), it must be related to the extreme conditions experienced with track driving in the northern Central Valley in California, where air temps were in the mid-90's.
Any thoughts?
Craig-o
Any thoughts?
Craig-o
