76okievette
Quick Question, I put some DOT 4 brake fluid in my 76 before I realized it was not DOT 3, I only put in a small amount but now I am concerned about it. Should I purge the system and replace all the fluid?
DOT 3 and DOT 4 fluids are mutually compatible, the major disadvantage of such a mix being a lowered boiling point. DOT 4 glycol based fluid has a higher boiling point (446F) than DOT 3 (401F), and both fluids will exhibit a reduced boiling point as water content increases.
If you haven't purged your system in a while, now may be a good time to do it.
Also great advice I will consider it. I don't know much about synthetic brake fluid but for your post it sounds like a no brainer to use it.
Which is the best type of "bleeder"? There are the hand pump used at each wheel, manual pump tank the fits over the resevior and also the type that uses compressed air which type does everyone recommend? I think I am going to flush out the DOT3 and Dot4 and go back with the orginal DOT3 fluid. Suggestions?
As I posted above, DOT3 and DOT4 fluid are 100% compatible - there's no need to flush the system just because you have both types of fluid in it. If you still want to flush and fill/bleed with fresh fluid, the Motive Products power bleeder (www.motiveproducts.com) is the best sixty bucks you can spend for a tool; makes the notoriously-difficult bleeding of '65-'82 Corvette brakes a ten-minute job for one person - no other method even comes close
Thanks John that power bleeder is what I was looking at Corvette Central sells it with an adapter for the C3's I think I will go with it. I appreciate it.
I am really flushing it because I have had the car for 3 years and have never done anything to the breaks they were completely rebuilt right before I got the car and still work but I would feel better flushing it out.
