Grizzly
- Joined
- Aug 23, 2002
- Messages
- 430
- Location
- Centerville, PA, USA
- Corvette
- 1967 Marlboro Maroon Coupe, 1992 White Convertible
I took JohnZ's advice and put a little of my brake fluid from my '67 in a test tube with some water and all I got was a milky mix so I guess I have standard brake fluid.
My question is are there any things I should be on the lookout for when flushing. Any special tricks? I have both a vacuum and a pressure bleeder.
I don't know if I have stainless brakes or not, but some have said if they are still working they must be stainless. Doesn't give me much comfort. The brakes are very heavy ( no power assist ) but I can stop the car and it pulls straight. I have no experience with non-assisted disc brakes so nothing to use as a standard. I would assume that the lining compound would have a lot of effect on how heavy they would be. Anyone have a suggestion for lining material that would not be too dirty and might be a little easier on the right leg?
Thanks...................
