Nobody Cares
- Joined
- Oct 7, 2006
- Messages
- 421
- Location
- Higgins Lake , Michigan
- Corvette
- red 81, orange 74 vert. , 80 claret,69 chevy pu
The brake light had been staying on for a couple of weeks. 1980 vette. Brake pedal was getting a little spongy. I changed the master cylinder today and bleed all the lines. Brakes are working great now. But the brake light between the speedo and tach stays on. I pulled the tan and white wire off the brake porportioning valve and the brake light went out. I tested the wire with a tester at the pug (where it plugs into the porportioning valve ) and there is power there all the time. I plugged it back in the porportioning vavle and the brake light stays on. Can anyone give some ideas what to do or check. THnx Dave
