93Rubie
I did a SCR Region auto-x drivers school today and I had a blast. Learned a ton about me and my Corvette. Counting this event that is 10 so far. I love it, and I'm hooked.
Now for the bad part. My instructor took the wheel after my first 6 runs and he put down a 7th. On the 8th run, the brake pedal went to the floor, suddenly. This was NOT brake fade, and we concluded it was NOT air or anything similar. When this happened the red brake light came and on I noticed the ABS Active light was on for a little bit. He got the car stopped by coasting in gear and using the hand brake. W
We popped the hood, no leaks, plenty of brake fluid. Another guy pushed on the pedal and it came right back. However, we elected to park it for a bit and let the car cool and asses the situation.
After lunch, I went back to the car. Pushed on the brake pedal, pumped up as it used up vacuum in the booster and got hard. Did not bleed down either. Good firm pedal. Started the car, still had decent pedal, did not sink. No leaks. I did notice that there was a "bump" feeling in the pedal. Not sure if this was there previously or not.
We decided to give it a try. I took the first lap kinda easy, but the brakes where find. I went balls out the rest of the afternoon with NO issues. Using the brakes hard.
The theory is this: Some junk in the master cylinder (I vacuum flushed the entire system this spring via Mity Vac with 1 qt. ran thru it) got into the seal area and caused it to leak internally. When this happened the pedal went south and the pressure differential switch did its job with the red brake light on. When we hit the pedal again, it moved the junk and worked fine. I did observe lots of extra junk in the resivoir that was NOT there before.
Comments on this?
Also, what brand do you recommend on master cylinders? AcDelco seems to be non-existanct. Seems the Corvette parts places our low on them as well. I tend to shy away from the Auto Zone, etc...remans, considering the driving I do. Corvette Central does sell a rebuild kit. Assuming I can get the resivior clean the and cylinder bore is good, this might be the best option.
Comments on this?
Also, would you do a complete system flush again or just bleed at the fittings on the master when installing? Its obvious which is less time consuming.
The ONLY other thing I could think it COULD be is a ABS Malfunction some black magic one in a trillion chance thing. No codes when I got home so....I doubt it.
FYI, I asked the instructor what he thought of my C4. He said it was very well balanced. Easy to drive, no surprises, very controllable when out of shape. Turns well. Lots of torque.
He did ask me what kind of alignment I had on it. I told him -.5 a degree at all four, zero toe in front, and as much caster as I can get.
He made the comment to the effect, its amazing what a alignment will do for these cars.
I asked him what mods he might do to it? He said, tires and maybe shocks. Leave the rest alone.
He typically drives a fast Honda, this year a Porsche GT3. Nice guy, very good driver.
I continue to be amazed by the C4 how good it handles, (when driven right), brakes, accelerates. Its easy to drive nature, communicative (to me) chassis feel/steering feel, (I'm never surprised by it).
I was nailing the 1st half of the course, 5 cone slalom medium spacing, skidpad, and Chicago box. I came out of the box so fast I didn't brake soon enough for the next turn and kept screwing up the last part of the course because of it.:eyerole
I gotta get this thing fixed, when is the next Auto-X?
Comments on this?
Comments on this?
