HammerDown
Anyone have any feedback about 'Cardone' remanufactured or new master cylinders?
Cardone is one of the better remanufacturers out there.
First, bench bleed the master by getting one of those bench bleed kits or making your own bleed tubes, one in each outlet running back up the each reservoir. Fill the MS, then slowly pump full strokes until there are no more air bubbles flowing out of the tubes into the reservoirs.
Reinstall the master then pressure bleed the rest of the system. Go RR, LR, RF, LF.
Do not use a vacuum bleeder on a C3.
Allow me to clearify...true, when bench bleeding I can indeed fully compress the piston/full strokes into its bore > as without anything to stop the fluid, it's simply exiting and reentering the MC.The seal design on C2/C3 disc brake calipers works very well at keeping brake fluid in but it doesn't work well in keeping air out.
When you use a vacuum bleeder, you're applying a vacuum to the brake caliper. It doesn't take much below atmospheric pressure to suck air, past the piston seals and into the brake fluid. The problem comes in being able to use a hand vacuum pump well enough to feel when you've applied just enough vacuum to the caliper to only suck out brake fluid and not pull air past the piston seals.
With C2/C3 you're always better to use manual (foot) bleeding, pressure bleeding or even gravity bleeding rather than vacuum bleeding.
As for bench bleeding, you have the right equipment, but you should be able to bottom the piston in the bore when bench bleeding. You already know, once the MS is installed that you can bottom the piston in the bore so, when you have it in the vise on the bench, push harder because, when you only move the piston an 1/8-in, you're not getting a full stroke.
