Bill Heygster
Is there a way to check brake pad thickness without pulling the wheels?
Not Really!!Bill Heygster said:Is there a way to check brake pad thickness without pulling the wheels?
Did you Turn the Rotor's??Dragon Daddy said:Hi.
If you replace the pads, use the stock ones. I installed after-market pads (identified as non-squeaking) and had nuisance squeaking probs.
So, stay with the stock (unless you are racing).
