eboch
My Z06 has an annoying sqeaking brake problem. I've dismantled the pads a few times .... adjusted the tin shims so that they apply more pressure to the pads ..... but the sqeaking continues to be there.
I'm thinking now that the problem is just the type of pads I have on there. Has anyone had this problem? ..... and then fixed it with new pads? ....what kind of pads did the trick?
eboch
PS: I have replaced the stock rotors with slotted & drilled ones .... the squeaking was/is there on both rotor types. The rotor change didn't help the sqeak ..... but did improve braking performance.
eboch
otfl
