LVMYVT76
If your master is empty in the rear, the fluid is going somewhere, wither the master is leaking or somewhere else is leaking. Need to find out where the fluid went and correct that problem.
So I finally have brakes. The first symptom I had was on Sunday after getting off the highway no amount of force could bring the car to a quick stop. If I pushed down the brake pedal, the car would eventually stop, but ever so slowly.
Check the hoses that go to the calipers also, they can make your peddle feel soft. They balloon out when they are week. Stainless ones will correct this.
Ive been wondering if mine is bad. It feels spongy about 1/2 way down. During this spongy part, the brakes dont function at all.
About 1/2 way down, the pedal gets hard but doesnt feel nice. I have to jam on it to get it to stop in a decent distance. Very dangerous...
Also, when it hits the hard part of the pedal stroke, the "brake" light comes on-on the tach(? maybe speedo, theres no guages in the car right now..)
You might want to do what SR7D1 did and replace both booster and MC to be safe (as I eventually did as well). My initial feeling was the MC was shot, but the brakes had worked for months even with the spongy pedal. If the power booster went on me at a critical time people including me could have died.
Unlike you my brakes seemed to work good besides the spongy feel and long travel it took to reach the braking.
If you can do it yourself, you can do it for cheap (around $150 total), but as you've read the labor is intensive.
A spongy pedal means air in the system, and if the "brake" warning light comes on, that means there's a pressure differential between the front and rear systems, which also indicates air (more in one system than the other).
Would this take the place of the method of running a hose from the caliper to a reservior of brake fluid (Bleeder bottle)? It seemed to bleed so easy using that method, does air hide in there and always cause problems on these vettes?The best money you can spend is $60 for a Motive Products pressure bleeder (www.motiveproducts.com) - bleeds any Corvette disc brake system in ten minutes and you'll have a nice hard pedal; puts any other method to shame.
The correct bleeding sequence is ALWAYS RR, LR, RF, LF - longest line first, shortest one last (which is NOT unique to Corvettes). The rear calipers have two bleeders - do the inboard side first, then the outboard side.
JohnZ---I'm confused! In one reply you said RR,LR,RF,LF. In a reply on the next page you said LR,RR,RF,LF. Which is it?
