chadwick88
Help....need someone's advice when it comes to brakes on a 79 L-82 (stick). Recently my brake warning light stays on without ever going off while driving. At first I thought it was my emergency brake handle not being pushed down all the way, but after playing with that for awhile it still was on. I have noticed when appling the brakes it is requiring more pressure on the pedal to stop the car (not much more, but more ). I have no leaks, and the cyllinder is full of fluid. The vacuum from the booster to the intake manifold is strong, so I am not losing any pressure there. I had my brakes checked about 3 month ago when I had new tires put on, and they were fine. I am not feeling any tugging or pulling to one side or the other when apppling the brake, or any noise from the brakes as well. My next step is to bleed the lines if needed, but thought I would shoot this out to the group first, anybody ever have this problem before???...I can tell you my emergency brake's do not work that well, hardly at all in fact...would this be the reason the brake light goes on, if so why???.... thanks in advance for your help....
