Brakes
  • Thread starter Thread starter Kritter
K
Kritter
Has anyone used Vettepartsonline.com to get brake parts? I have called them several times and just get an answering machine. In addition, their website http://www.vettepartsonline.com[/URL] is disabled.
Just wanted to confirm that someone else had gotten parts from them.
Kritter
If this is the vendor in Florida (Delray Beach I believe) then shop at your own risk. Many people have reported horror stories with this vendor.
Thanks for the information, I wondered because I was getting an answering machine, then no one would call back.
Kritter:blow
"Kritter": Sounds like somehing's wrong here, if all you get is an answering machine when calling & the web sites down. Go with somebody else. There are so many brake vendors out there it'll make your head swim. Good luck!
Dave:CAC
One more thing, I've been looking for the "O-Ring" designed caliper and the only one I've found is VBP. Is that the only one that sells that design?
I figured I should post another based on my latest finding. "Fixvetteparts.com" has the SS sleaved O-ring caliper for $66 each or $329 with pads, lines, bolts, and calipers. I guess I'll go with them unless someone has had bad experiences with them.
Thanks for the responses.
Kritter
Kritter,
I had these guys (fixvetteparts.com) do my calipers, T-arms and rear about two years ago and they did a fine job. And the price was definately right! :upthumbs
Good luck,
Steve :w
